You say you have a 153 tooth flywheel is this for a auto or manual trans most 153 tooth flex plates I see are for later model small blocks with auto Tanny's and most of the flywheels I have seen for big block are 168 tooth???
witht he 153 tooth fly wheel your gona nee the starter with the hole directly across from eachother...(straight)
the 168 takes the angles style.
i ended up just buying a racinf one cause it will fit both sizes.
Related Threads
Hot Rod Forum
2.2M posts
175.6K members
Since 2001
