Which flywheel is it? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-22-2005, 08:05 PM
classic_chevy_guy's Avatar
70Chevelle/91Eclipse
Last journal entry: My 81 Silverado(SourApple)
Mini starters and a Muncie 4 speed question 4 the pros.
Does anybody have any good reviews about their mini starters, im thinkin about gettin one and i dont wanna waste my $$$ that i worked all week 2 get? The mini starters come with a straight bolt pattern and 2 different mounting options, so they'll work with both 153 and 168 right?
My next ? is this: If im runnin 4:11 gears out back in a 84 Z28 Camaro with a mild 350, should i go ahead and keep the TH-350 or have more fun with a Muncie 4 speed? Im not all that good with gear ratios, i mean i understand it, but i dont have very much experience with it and i dont wanna thrash my beautiful rearend that came with the car. So if i wanted 2 put in a 4 speed would i go close or wide on the gears? Im thinkin wide, but then again im worried about that gradually build up on speed, like the big diesel truck trannys that take 4 ever 2 get up 2 gear, and ive never owned a 4speed so i dont know about this, but 1 of my friends said that id need a wide ratio for the 4:11's, but id have 2 put up with the gradual build up of speed, does he need a slap in the face or handshake?
Old 04-22-2005, 08:53 PM
bracketeer's Avatar
489 Lemans
Last journal entry: Street Legal
flywheel
Yes the mini starter has 2 inline bolt patterns for either ring gear/flywheel. But some older blocks do not have the inner hole. You have to drill and tap a hole.
Old 04-22-2005, 09:07 PM
well thank god mines already got 2 mounting locations, i hate drilling and tapping.
T5 flywheel question transam-man305 Transmission - Rearend 1 01-12-2005 08:12 PM
Removing flywheel to converter bolts in a 1958 Chevy Impala 348 Cast Iron Powerglide 1958imp348 Transmission - Rearend 9 11-22-2004 03:18 PM
Flywheel Inertia BillyShope Suspension - Brakes - Steering 3 09-02-2004 06:44 PM
clutch disc springs hit flywheel bolts 72chevy240z Transmission - Rearend 6 05-05-2004 02:21 PM
Flywheel balancing? nomis30 Engine 3 11-25-2003 11:03 PM
