Flywheel for 89 Chevy 350? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-29-2007, 05:07 PM
Can I use an older flywheel on a newer motor? I have a few older flywheels and would like to be able to use one instead of buying a new one. Motor is an 89 Chevy 350 with one piece rear main seal. Do I need an adapter or can I bolt one right up? Thanks for any help.
Old 04-29-2007, 06:29 PM
monte mike's Avatar
hi
should bolt right up
Old 04-29-2007, 07:41 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
the one piece rear seal 350 cid motor uses a smaller bolt pattern on the crank shaft as i recall ....... than the early 2 piece rear main seal engines.
Old 04-29-2007, 11:41 PM
NO you cannot use a old flywheel on a newer 350 or visa versa for one the bolt pattern is completely different and two the 89 has an external balance and the old will be neutral balance.
You will need to buy the proper flywheel for your engine
Old 05-01-2007, 07:31 AM
Hey SHAD it just so happens i have 2 of the external balanced flywheels for the motor your looking for. If your interested pm me maybe we can work out a trade or something.
Hi. just wondering why the 350 chevy small block is so good... judgedredd Hotrodders' Lounge 78 06-25-2010 08:01 AM
350 chevy help joesnova2 Engine 7 11-08-2009 05:46 AM
buick 350 - chevy 350 72buick Engine 23 10-13-2009 08:38 PM
El Camino Engine - 350 Chevy or 455 Pontiac bjam2 Engine 16 08-07-2007 03:45 PM
can a 350 flywheel be balanced for a 383/400? fiscus Engine 4 04-03-2007 07:07 AM
