Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Flywheel aluminum or steel
Old 02-15-2011, 07:15 PM
72bluemalibu 72bluemalibu is offline
Hi Im in process of building a SBC 415". About 600 HP. The trans will be a Liberty 5 speed with a Ram dual cluth. The question is to run a aluminum or steel flywheel. This will be a street car at about 2900 lbs. Gears will be 4:10 with 28" tall tires. I'm told there may be some chatter off the line with the aluminum flywheel. Thank you for any and all advice.
