flywheel bolts - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-10-2005, 07:18 PM
raidmagic's Avatar
Last journal entry: electric fans
flywheel bolts
Hey guys Do flywheel bolts have to be anything special? I have a 454 that was mated to a standard trans and I am going to use it with an auto, the problem is the stock bolts are too long to work with the new flywheel. Can I cut them down? Are they heat treated?
Thanks
Old 05-10-2005, 07:21 PM
302 Z28's Avatar
They are grade 8 bolts. I would try and find the right bolts rather than cut them down. The right bolts must penetrate far enough to have the required thread engagement.
Vince
Old 05-10-2005, 09:19 PM
They're only $12 at Rick's Camaros, pn CL-49. A local speed shop or Chevy dealer should have them, also.
Old 05-10-2005, 09:21 PM
MI2600's Avatar
Member# 3287
If the bolts are like the SBC, the flywheel bolts are 1" and the flexplate bolts are 3/4". Most auto stores have them.
Removing flywheel to converter bolts in a 1958 Chevy Impala 348 Cast Iron Powerglide 1958imp348 Transmission - Rearend 9 11-22-2004 03:18 PM
327 flexplate / flywheel bolts backing out bigmacou Engine 5 09-07-2004 06:38 PM
Flywheel Inertia BillyShope Suspension - Brakes - Steering 3 09-02-2004 06:44 PM
clutch disc springs hit flywheel bolts 72chevy240z Transmission - Rearend 6 05-05-2004 02:21 PM
Removing fenders? Jag Daddy Body - Exterior 3 11-26-2003 04:42 AM
