Flywheel cover bolts - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-03-2008, 05:16 PM
ss396si's Avatar
I have a TH400 behind a 305,I'm putting in a flywheel cover,I don't know what size bolts i need.
Thanks
Old 09-03-2008, 05:31 PM
T-bucket23's Avatar
Wiki Edits: 26
Thanks
I believe 1/4 20 will work. Some had almost like a sheet metal screw
WHY DOES THIS "10 BOLT" HAVE 12 BOLTS? :( wyomingoutlaw Transmission - Rearend 7 01-28-2007 04:42 AM
FLyWHEEL QUESTION. 4.3L 5 spd flywheel work in t5 with clutch? boneyard Buick Engine 0 11-17-2006 07:20 PM
Flywheel Bolts rj57 Transmission - Rearend 5 05-16-2006 08:04 PM
Correct sequemce for body panel alignment Ripped Body - Exterior 4 10-19-2005 08:14 AM
Flywheel cover tips? Fragzem Transmission - Rearend 0 11-10-2003 05:59 PM
