Flywheel Covers - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-02-2003, 12:05 AM
former member of HR.com
Post Flywheel Covers
This is one I can't figure out. I also can't figure out where to ask the question. Why are aluminum flywheel covers so much more expensive then say steel or chrome plated flywheel covers?
Old 03-02-2003, 12:25 AM
Post
I would guess cause they wieght less.
Old 03-02-2003, 06:12 AM
milner's Avatar
Post
you didn't mention if you where referring to and original aluminium cover. if so they are casted, where the steel ones are stamped. and also aluminum is a more expensive material.
Old 03-03-2003, 06:21 AM
Post
One of the many mysteries about my 'Bird is that there is no flywheel cover at all. This leads me to think that maybe the engine was replaced before I inherited her. So the question would be aimed at an after-market cover. Do you see a difference in using one over another (Aluminum v. Steel)? Thx...K
Old 03-03-2003, 07:20 AM
Barz51's Avatar
a.k.a. Rusty Shackelford
Last journal entry: Another one
Post
If you are running 10 seconds or less I would go with the aluminum. But on the street the weight saved is not going to matter. The cheaper the better. The only thing a chrome cover will do is give the guys in the pit at the oil change something shiny to look at
Cory
Old 03-03-2003, 09:09 AM
bullheimer's Avatar
NEVER use credit cards!
Post
a steel one weighs like 6 ounces. get one. it's to keep crud off your clutch or whatever. rear seal front seal, navy seal
