Flywheel Education - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-07-2010, 06:29 PM
Flywheel Education
Building a 454HO Gen VI.
Starting at the bottom and moving up to the top.
Looking for around 700 HP and need some flywheel advice
for an automatic trans. What should I do and why?
Thanks!
Old 11-07-2010, 07:43 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Automatic transmissions use a flexplate. Flywheels are for standard transmissions.
You will want an externally balanced flexplate w/SFI certification, and made for a 1-piece rear main seal crankshaft- unless you go w/an internally balanced rotator.
Some are shown HERE.
FLYWHEEL question: t-5 (V8) and 4.3L 5 spd flywheel boneyard Buick Transmission - Rearend 1 07-20-2009 10:43 AM
Flywheel Swap / Engine balancing HP52TA Engine 8 04-10-2009 06:18 PM
FLyWHEEL QUESTION. 4.3L 5 spd flywheel work in t5 with clutch? boneyard Buick Engine 0 11-17-2006 08:20 PM
Removing flywheel to converter bolts in a 1958 Chevy Impala 348 Cast Iron Powerglide 1958imp348 Transmission - Rearend 9 11-22-2004 04:18 PM
Flywheel Inertia BillyShope Suspension - Brakes - Steering 3 09-02-2004 07:44 PM
