Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Flywheel & Mini High Torque Starter Too Close Together
Old 02-22-2012, 03:40 PM
mason71's Avatar
mason71 mason71 is offline
Last journal entry: mock up
Hello, first off thanks for any help!
I have a sbc 350 with a new Fidanza aluminum conversion flywheel (2 piece rms block to LT1 style T56 6 speed) and a high torque mini starter that are too close to each other when you bolt everything up. Check out the pics.
What do I do? The starter came with this shim but its not enough.
Do I make another like this to move the starter forward and get longer bolts for the starter or shim the flywheel back? Wouldn't that mess up my clutch engagement?
Thanks
