Flywheel not lined up - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 03-06-2010, 04:49 PM
so i just got back from a parts supplier it appears that the flex plate is not correct for this trans it turns out i need a flex plate from a 307 to work looks i will be waiting for awhile seeing as how it is on back order the other option would be drilling the holes myself anyone have any expieriance with that
  #17 (permalink)
Old 03-06-2010, 04:53 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
FWIW, I would wait for the right one to come in. JMO
Cole
  #18 (permalink)
Old 03-06-2010, 05:03 PM
thanks for everyones help
  #19 (permalink)
Old 03-06-2010, 05:11 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
just a moderator note here;
a member may not read all the posts before their answer is typed and posted. You folks know this, I am just mentioning it.
Nothing like a wrong flywheel plate to goof up an install.
  #20 (permalink)
Old 03-07-2010, 08:12 AM
Rickracer's Avatar
ASE Master Tech, Fabricator
Last wiki edit: Taurus 2-speed fan control wiring diagram Last photo:
I have drilled flexplates before, and successfully. The thing to remember is that the holes do not line the converter up, nor do you want them to. That job falls to the pilot on the front of the converter. So if your holes are just slightly larger than the OEM ones, it will not hurt anything. If you have a flexplate with the correct set of holes to use as a template, or if your converter has the strap type mounting lugs, where you can mark the holes from the backside, you can duplicate the bolt pattern. Or, with no flexplate or converter straps to use as a template, you could take the one you have to a machine shop and have them drill an accurate pattern.
  #21 (permalink)
Old 03-07-2010, 09:53 AM
that helps more specifically im not sure how to post a picture but you can google a 305 th350 plate to see. If i turn the converter to line it up with a plate hole the converter stud is covering the inner half of the flexplate to converter mounting hole are you saying just drill the original hole larger then with the the use of a high grade washer or bolt with a bigger head perhaps?? if you dont mean this could you show me an appropriate location to drill
  #22 (permalink)
Old 03-07-2010, 10:02 AM
Rickracer's Avatar
Does your flexplate have 6 "pads" or just the three? This one has 6:
If yours has 6, just drill the ones with no holes. If it only has 3, and your holes will have to become "slots", I'm not sure I'd be comfortable with that.
BTW, the one in the pic is at Speedway Motors, like $24, http://www.speedwaymotors.com/1986-9...ign=GoogleBase
  #23 (permalink)
Old 03-07-2010, 10:31 AM
it does indeed have six hence my aprehension about slotting them and im guessing it is not wise to dril through the other sections i did find this locally im curious if it will work for my application from summit racing part# SUM-G100SFI.
  #24 (permalink)
Old 03-07-2010, 09:13 PM
Rickracer's Avatar
If yours looks like the one above, minus one set of holes, you could drill the blank pads. Now if it has 6 holes, and the pattern you need is different than either one, I think I'd wait for the right one.
FLYWHEEL question: t-5 (V8) and 4.3L 5 spd flywheel boneyard Buick Transmission - Rearend 1 07-20-2009 10:43 AM
Flywheel Swap / Engine balancing HP52TA Engine 8 04-10-2009 06:18 PM
FLyWHEEL QUESTION. 4.3L 5 spd flywheel work in t5 with clutch? boneyard Buick Engine 0 11-17-2006 08:20 PM
Removing flywheel to converter bolts in a 1958 Chevy Impala 348 Cast Iron Powerglide 1958imp348 Transmission - Rearend 9 11-22-2004 04:18 PM
Flywheel Inertia BillyShope Suspension - Brakes - Steering 3 09-02-2004 07:44 PM
