Flywheel question - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-15-2007, 08:51 AM
k2c1959's Avatar
Flywheel question
This may have been beat to death, not sure, but.. I have a 79 Chev 350 motor and 79 350 Turbo tranny. I m putting this into a 67 chev SB stepside.
My question is why is the 305 flywheels and the 350 flywheels so much diffferent in size? Stupid me, when i took the engine off the stand to put into the truck i had 3 flywheels laying on the bench .. 2 small ones and 1 big one, and I just grabbed one (of the small ones without any thought) and bolted it to the engine and put the engine in and then put the tranny in and bolted everything up until I got to the torque converter......... ..the bolt holes in the torque converter dont match up to the bolt holes in the flywheel... ....so now I have to take everything back apart again to swap flywheels.. i am dazed and confused here, never noticed that difference before... is that normal
Old 06-15-2007, 12:08 PM
Jmark's Avatar
Yes, this is normal. Chevy uses 2 different diameters/tooth count flywheels. Just your luck you grabbed the wrong one! LOL
Mark
Additional 50hp from heads, or 200+lbs off the nose from a LW front suspension clip? NLang General Rodding Tech 29 12-15-2005 02:31 PM
T5 flywheel question transam-man305 Transmission - Rearend 1 01-12-2005 08:12 PM
Hi All I just Joined, Questions Re:454 rebuild Gay-Shark Engine 8 11-29-2003 10:25 AM
Flywheel balancing? nomis30 Engine 3 11-25-2003 11:03 PM
Revisiting the Flywheel question??? Kaylah Hotrodding Basics 5 09-26-2003 11:53 AM
