Flywheel Questions - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-08-2003, 08:29 AM
Flywheel Questions
How do I count the teeth on my flywheel? I'm haveing loud starting noises, and have tried shimming, but I still get the embarassing cranking noise. I have a crate 350/350 w/ 350TH.
Old 07-08-2003, 10:10 AM
johnsongrass1's Avatar
Race it, Don't rice it!
1...2...3...4...5...6...7.............7........... 7 Oh darn gotta start over!
WE NEED DETAILS PLEASE,
Old 07-08-2003, 11:37 AM
O.K. I was told that I had to have the correct flywheel for the starter, so I want to check the teeth tosee if it is a 168. That is the correct teeth for a SB350 isn't it?Trying to solve a loud cranking noise, not zzzzzzing, or zzzzzzzzzzipping sound. Have checked tolerences already.
Old 07-08-2003, 11:49 AM
crazy larry's Avatar
Last journal entry: better comparison before and after shots
is it more of a zzzzzzzzppping noise or is it more of a zzzzzrrrrking sound? does it go rrrrr rrrrrr rrrrrrr wwwwaaackkk?
has it ever gone sssskkrrrrrreeeeekkk?
lmao
Old 07-08-2003, 12:58 PM
FoxThunder 5.0's Avatar
i think its broke...
its most likely ur starter motor. does it at all stick to the flywheel after start?
Old 07-08-2003, 02:00 PM
New starter because the old one was doing it too and I thought it was the starter. Besides how would you describe the noise to someone who hadn't heard it??????/
Old 07-08-2003, 02:01 PM
I think I'll go back to chevy talk the peeps there are much nicer
Old 07-08-2003, 02:09 PM
No need to run away sad and angry, Just be mindful of what you are asking and give us all the details you can. Especially stuff youve already troubleshooted yourself. We at this board have a code of etiquette so everyone knows what's going on and we cam help each other better in this manner. Read the "before you post" and you will see why this board is the most helpful, courtious one you can find.
Year, make and model of your truck will benifit all of us.
Old 07-08-2003, 02:17 PM
You may have a bad flywheel..
The 153 Tooth flywheel measures 12 and 3/4 inches and the 168 Tooth flywheel is 14 inches in diameter. That is 1 and 1/4 inches difference total and as a general rule the staggered bolt hole starter (168T) will not even touch the 12.5 inch flywheel (153T). The 153T starter (the straight accross pattern) is way to off to engage the 14" (168T) flywheel.
This is a 153 T (12.75") flywheel starter
Old 07-08-2003, 05:25 PM
i had a related problem with mine, and it was making a crunchy grinding sound after the motor was started. i actually had a defective motor :skeptic:
Old 07-08-2003, 08:07 PM
1964 Chevy C-10 custom, 350/350 crate engine,headers,edelbrock intake, holley carb, HEI, 1 wire alternator,new radiator,new battery,completely new wiring,new starter,with 350 TH automatic. The starter was making the noise before I installed a new one. Thats why I replaced it in the first place.I have shimmed the starter to acheive the required tolerances, and the starter is the staggered bolt type.Still get the loud embarassing cranking noise, not associated with improper shimming.
Old 07-08-2003, 09:25 PM
The year, and staggerd bolt pattern tells ya it's got the 168 tooth flywheel. Earlier as duece had said, you almost can't get them wrong. The 158 tooth flywheel is used for small clutch(10.5")small flywheel application where bellhousing's are really small like in the camaro's and firebird's who have limited floor space. The 153 also used the straight bolt pattern.
Old 07-08-2003, 10:30 PM
troy-curt's Avatar
Shop Owner And Troll Hunter
Like deuce said, i`ve seen flywheels do that.
Good Luck,
Troy,
Old 07-09-2003, 12:46 AM
Gooch,
dont get mad, i was funnin. hence the lmao, stick around, learn and share......
Old 07-09-2003, 07:22 AM
sorry for the short fuse, I'm not usually as quick. I'm at my ropes end with this and it looks like a new flywheel in store.
