Flywheel Size - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-12-2012, 10:31 AM
Flywheel Size
Good Morning,
I need to buy a starter adapter plate as I can no longer mount my starter. This system uses 168 tooth flywheel.
I have a 67 Camaro rs with a 327 and a TH350 installed. How do you tell which flywheel you have while it is installed. Dumb Question! Thanks for any advise.
Old 03-14-2012, 09:47 PM
flywheel
168 tooth flywheel has a stagered bolt patern a 154 tooth flywheel has a staright bolt patern if the block is stripped and the starter can't bolt to the block you can use a chevy truck belhousing 1957 to ? the starter bolts to the belhousing you can only use a 168 tooth flywheel. hope this helps
700R4 flywheel dust cover screw size? Curmudgeon29 Transmission - Rearend 3 11-22-2011 05:53 PM
FLYWHEEL question: t-5 (V8) and 4.3L 5 spd flywheel boneyard Buick Transmission - Rearend 1 07-20-2009 10:43 AM
best size flywheel/clutch size for a TRUCK itstorque Transmission - Rearend 2 02-21-2008 02:07 PM
FLyWHEEL QUESTION. 4.3L 5 spd flywheel work in t5 with clutch? boneyard Buick Engine 0 11-17-2006 08:20 PM
flywheel size. molevolent_creations Engine 2 10-27-2003 03:36 PM
