Flywheel for tilton 7.25 clutch on a 454 - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-21-2012, 07:26 AM
I got a tilton 7.25" 3disc clutch together with a tko600.
Which Im planning to use it behind a supercharged 454 on the street.
Can anyone recommend a flywheel to use for that application?
Or a flywheel, bellhouse, starter combination..
Got a starter for 168 tooth flexplate, but can get another one...
Internally balanced crank.
Thanks
Old 08-21-2012, 09:01 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Installtion instructions for the tilton clutch..
http://www.tiltonracing.com/sites/de...c%20Clutch.pdf
Sam
clutch and flywheel 80camaroguy Transmission - Rearend 4 04-12-2012 08:54 AM
Clutch/Flywheel Recommendation? mrdreex Transmission - Rearend 1 11-26-2008 02:12 AM
flywheel and clutch question gilliganspl Transmission - Rearend 6 08-26-2007 07:29 PM
FLyWHEEL QUESTION. 4.3L 5 spd flywheel work in t5 with clutch? boneyard Buick Engine 0 11-17-2006 08:20 PM
M21 to M22 - clutch and flywheel help DarwinBrooks Transmission - Rearend 13 02-08-2006 06:33 AM
