Start a tech article on any subject...
...hundreds of hotrodders help build it into a comprehensive resource.
Fresh wiki articles that you can add to: Air suspension on a front solid axle, Basic stuff for newbies, Building a new shop, Ceramic insulation, Electric fuel pump mount, Engine and transmission mounts, Freeing a stuck engine, Gasser, How to check driveline angle, How to make a vacuum power brake bleeder, How to safely cut steel with a torch, Improving fuel economy, Narrowing a rearend, Patching a body panel, Quick-disconnect rear mount battery, Reducing vehicle weight, Stereo installation, Stripping paint, Valve spring setup, and many more...
Or, start a new article.
Hotrodders Bulletin Board > Tech Help > Transmission - Rearend
  #1
Old 01-02-2003, 06:09 PM
bg's Avatar
bg bg is offline
Post flywheel tooth???
A ZZ4 355hp engine comes with a small flexplate about 12 3/4 inches wide. (158 tooth maybe)
I assume this is for a manual transmission and i would have to switch to a larger (14inch 168 tooth) flywheel for an 700r auto tansmission.......
Is this correct..........
Also is the starter bolt pattern straight or staggered??????????
bg
Old 01-02-2003, 06:25 PM
Deuce Deuce is offline
CURMUDGEON / MODERATOR
 Deuce's barnstar
Post re: flywheel tooth???
[ January 03, 2003: Message edited by: Deuce Roadster ]</p>
Rat Rods are for those who cannot build a real Hotrod ...
Old 01-03-2003, 02:51 AM
roys63's Avatar
roys63 roys63 is offline
153 flywheel uses a straight bolt starter and 168 the other, Right!
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
