Flywheel Torque - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-01-2011, 07:32 PM
Flywheel Torque
What is torque specification for flywheel bolts on Chevy SB?
Ditto for Auto transmission to block?
Old 07-02-2011, 12:44 AM
SSedan64's Avatar
Flywheel = 60ft/lbs. w/Loctite
Bellhousing = 30-35ft/lbs. oil
http://www.small-block-chevy.com/assemblyspec.html
http://www.chevytech.info/1c9o1.html
Torque Specifications for converter to flywheel mleo5161 Transmission - Rearend 1 06-17-2010 06:54 PM
torque specs for my clutch and flywheel? John 1954 Transmission - Rearend 1 06-23-2007 10:43 PM
Torque converter to far from flywheel Mighty Mouse S-10 Transmission - Rearend 4 02-26-2005 01:44 PM
Torque converter and flywheel Novaman78 Transmission - Rearend 8 01-29-2005 05:30 PM
flywheel torque = to flex-plate torque?? bullheimer Hotrodding Basics 2 05-26-2004 11:24 AM
