FMX or C6 - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-09-2003, 08:31 PM
New Member
Post FMX or C6
I'm wondering how I can tell weather my tranny is a c6 or an FMX.
Old 04-10-2003, 03:31 PM
woodz428's Avatar
Troll Hunter
Arrow
The easiest way is to look at the tranny, if it is a one piece aluminum case it is a C6, if it has a separate bellhousing of aluminum with a cast iron main case it is the FMX (after '66 prior to that it is a cast iron cruiso, valve bodies being the main difference) if it has a separate bellhousing and both the case and bellhousing are aluminum you most likely have a C4.
