Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - FMX in car rebuild?
Old 08-20-2012, 07:43 PM
66GMC's Avatar
66GMC 66GMC is offline
Get in, sit down, hang on
Last journal entry: Cab Removal
Agreed. That FMX is probably one of the easiest transmissions to remove.
1.) remove the driveshaft, linkage, fluid lines, etc.
2.) 2 bolts at the mount, 2 more on the cross-member.
3.) 4 bolts that attach the trans to the bell-housing (similar to manual trans)
4.) Slip the entire cast body back, and lower it down.
You can (optionally) remove the bell-housing and convertor later.
