Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - FMX in car rebuild?
Old 08-20-2012, 09:25 PM
cliff tate cliff tate is offline
fmx trans
remove the trans in 1 chunk,or you will damage the front pump or fp drive. remove torqe to drive plat bolts,then suport on a good floor jack,remove bell housing bolts and rear cross member. ouit she comes . be sure to pry the torqe back after the 4 torqe to drive plate nuts ar removed.then remove the bell h bolts.
