Originally Posted by cliff tate
remove the trans in 1 chunk,or you will damage the front pump or fp drive. remove torqe to drive plat bolts,then suport on a good floor jack,remove bell housing bolts and rear cross member. ouit she comes . be sure to pry the torqe back after the 4 torqe to drive plate nuts ar removed.then remove the bell h bolts.
you sure? it seems that it can be done that way its just put it back in that gets to be more complex that way
