-   -   FMX in car rebuild? (http://www.hotrodders.com/forum/fmx-car-rebuild-223123.html)
mikenite12 08-20-2012 04:12 PM
FMX in car rebuild?
i need to rebuild my transmission and in searching for pointers on this specific one i kept seeing it be mentioned that it can be done with it still in the car?!
so just wondering if anybody could elaborate or point me in a good direction didnt find much searching
thanks in advance!
Crosley 08-20-2012 07:03 PM
the trans is not rebuilt in the car... what happens is you can disassemble the transmission piece by piece from the car.
Reverse the order to install parts.
this was a method used in first gen T-bird cars.
Makes no sense to do this method on a car where the trans can be removed in one piece
66GMC 08-20-2012 07:43 PM
Agreed. That FMX is probably one of the easiest transmissions to remove.
http://www.charlietranny.com/FMX%20top.JPGhttp://www.charlietranny.com/FMX%20passenger%20side.JPG
1.) remove the driveshaft, linkage, fluid lines, etc.
2.) 2 bolts at the mount, 2 more on the cross-member.
3.) 4 bolts that attach the trans to the bell-housing (similar to manual trans)
4.) Slip the entire cast body back, and lower it down.
You can (optionally) remove the bell-housing and convertor later.
cliff tate 08-20-2012 09:25 PM
fmx trans
remove the trans in 1 chunk,or you will damage the front pump or fp drive. remove torqe to drive plat bolts,then suport on a good floor jack,remove bell housing bolts and rear cross member. ouit she comes . be sure to pry the torqe back after the 4 torqe to drive plate nuts ar removed.then remove the bell h bolts.
mikenite12 08-21-2012 01:50 PM
you sure? it seems that it can be done that way its just put it back in that gets to be more complex that way
cliff tate 08-21-2012 06:22 PM
c4 trans
do it your way,it is your trans and you did ask for advise.you can lead a horse to watter but cant make it drink.good luck
mikenite12 08-21-2012 06:46 PM
not trying to be rude man, just wondering considering it seems like a divided view on this some say you can and some say you cant
anglia427 08-21-2012 08:37 PM
fmx
it can be done in car but you still have no acess to the pump and converter imo its a half assed way for a fix as stated above better to pull it out and do a first class rebuild
