FMX in car rebuild?
i need to rebuild my transmission and in searching for pointers on this specific one i kept seeing it be mentioned that it can be done with it still in the car?!
so just wondering if anybody could elaborate or point me in a good direction didnt find much searching thanks in advance! |
the trans is not rebuilt in the car... what happens is you can disassemble the transmission piece by piece from the car.
Reverse the order to install parts. this was a method used in first gen T-bird cars. Makes no sense to do this method on a car where the trans can be removed in one piece
At the Bonneville Salt Flats, first gear is known as 130 mph. |
Agreed. That FMX is probably one of the easiest transmissions to remove.
1.) remove the driveshaft, linkage, fluid lines, etc. 2.) 2 bolts at the mount, 2 more on the cross-member. 3.) 4 bolts that attach the trans to the bell-housing (similar to manual trans) 4.) Slip the entire cast body back, and lower it down. You can (optionally) remove the bell-housing and convertor later. Last edited by 66GMC; 08-20-2012 at 07:49 PM. |
not trying to be rude man, just wondering considering it seems like a divided view on this some say you can and some say you cant
fmx
it can be done in car but you still have no acess to the pump and converter imo its a half assed way for a fix as stated above better to pull it out and do a first class rebuild
| 68 Impala Custom 396 Car rebuild | AZImpCus68 | Introduce Yourself | 1 | 10-15-2011 04:17 PM |
| Marine holley 4150 on my car, rebuild? | fiscus | Engine | 3 | 11-09-2007 04:19 AM |
| Fmx | carnell | Transmission - Rearend | 20 | 10-10-2006 07:20 PM |
| 69 Fmx | Gassman | Transmission - Rearend | 3 | 04-25-2005 07:54 PM |
| FMX or C6 | Jeff69cat | Transmission - Rearend | 1 | 04-10-2003 03:31 PM |
