fmx rear band replacement - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-02-2012, 05:01 PM
well i got my trans out and im almost done with the rebuild but im having trouble sourcing a new rear band (front band was fine the rear one was cooked) can a front band be used on the rear is there a difference i cant find much info on this subject
Old 09-03-2012, 05:48 AM
SSedan64's Avatar
They don't look the same. Part#'s are also different.
You may have to have yours relined.
FMX Transmission Parts Bands
Alto, Raybestos, Borg Warner etc...
It does look like WIT has one available: Small/Med Case.
https://www.wittrans.com/showfilter....31&Section=136
Old 09-03-2012, 11:29 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Band design is different, check the servo lug shape end that engages into the band
Old 09-03-2012, 12:47 PM
thanks for the info guys!
also while i have your attention while assembeling my clutch pack for the rear clutch drum this morning i noticed that the old pack had tow metal plates without a clutch disk between them....is that standard?
if i do it like that ill have one extra clutch disk at the end of assembly
so kinda curious about that
Old 09-03-2012, 05:36 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
two steel plates against each other is not standard. Some one made and error or they did that to maintain proper clearance. that is what you need to do is setup the clutch pack with proper clearance.
Some of the modern frictions for these vintage trans are different thickness than the OEM parts were. You need to measure and watch how the pack is setup
Old 09-03-2012, 06:46 PM
didnt think so when i re assembled it i used a disk in between where the two steels were and i got the proper clearance...
Old 09-18-2012, 05:03 PM
wil that one for the small/med case work for one thats going behind a 351m?
Old 09-18-2012, 08:18 PM
SSedan64's Avatar
Looks like there're 3 different Rear Bands which are Case specific.
Small/Med 1955-1981
Small/Med 1951-1955
Large 1955-1972
Wide band or narrow band A/F...? staleg Engine 6 08-12-2008 02:10 PM
Rear Quarters Replacement mightycarlo10 Body - Exterior 1 07-13-2008 03:11 PM
best band 2003 Audioslave. best band 2004 Velvet Revolver bullheimer Hotrodders' Lounge 21 02-02-2005 09:43 PM
Rear end gears and power band NovaSS350 Engine 45 10-05-2004 03:14 PM
Rear Axle Replacement MHenricks Transmission - Rearend 2 09-16-2002 08:06 PM
