We're winning the case!
Hotrodders Bulletin Board > Tech Help > Interior
  #1
Old 06-25-2003, 01:20 PM
Rubberman2003's Avatar
Rubberman2003 Rubberman2003 is offline
foamlike door panels...
Ive saw on a few site that people have this foam like stuff that have flames on it, they use for door panels and headliners. Where can i get this stuff, they all had cars like mine, third gen Fbodies. I think it looks kinda cool. AND how is it that i can make a kick panel for my 84 Z28? what material would i use ect ect?? Thanks
Old 06-25-2003, 02:09 PM
horvath's Avatar
horvath horvath is offline
Acoustic Rock ... for real.
Those are kits that you can buy ... I'm not sure where, because I prefer making original designs and, also, they're like $250 per panel.
Here's One
Alan
54 Chevy Pickup
Old 06-30-2003, 11:54 AM
59Chebby 59Chebby is offline
door panels
http://www.roddoors.com/Default.htm , you might try here also
Old 07-02-2003, 02:17 PM
battman140's Avatar
battman140 battman140 is offline
that foam is called landau foam. it's more rigid than normal foam so it works good for making reveals (raised flames, patterns, etc...). it's extremely hard to find though. i couldn't find it at any local fabric or upholstery stores. try doing a lookup on the internet. if you can't find it you can use a thin piece of wood - 1/8" or so. wood isn't as flexible but will work on door panels. i'm not an expert but i'm making some panels right now for my 84 trans am. if you need help let me know.
Old 07-02-2003, 09:23 PM
kristkustoms's Avatar
kristkustoms kristkustoms is offline
First name...............Shawn
Closed cell foam, or Landau foam (got the name from Landau tops) is very easy to find in my area. I have never heard of a upholstery shop that wouldnt have 1/4" closed cell foam around, or be able to call any of their suppliers and order some. But yes, that is what can be used to make raised patterns in panels
Old 07-03-2003, 04:53 PM
gt2betubbed's Avatar
gt2betubbed gt2betubbed is offline
Kid With A Wrench...
I was just curious, do you "carve" your pattern that you want into the foam? And after that, how do you attach the material that you want to use to it? Do you just use some type of spray adhesive?
Old 07-03-2003, 09:22 PM
just cut the design out with an X-acto knife. yes, double contact spray adhesive is used.
Old 07-28-2003, 06:21 PM
56F-100 56F-100 is offline
Foam
Look here http://www.globallayer.com/appserve...in.aspx?oii=226
They have foam
Sorry I gave you the wrong address for the foam. Here it is : http://www.keystonbros.com/markets.html
Good Luck.
I think if you go here or to a local upolstery shop in your area should will find it.
When you do cut it to your design do so on a slight angle so the material you cover it with will sit better.
Old 07-29-2003, 06:35 PM
mab46's Avatar
mab46 mab46 is offline
New Member
closed cell foam
i was at KEYSTON the other day. they have all the closed cell foam you need. $7.00 a yd
Old 01-12-2004, 01:29 AM
hungrymonkey hungrymonkey is offline
anyone found an online source? keystone does not currently does not sell online.
Old 01-12-2004, 02:51 AM
Dutchman's Avatar
Dutchman Dutchman is offline
Old Salt
Old 01-12-2004, 07:35 AM
phattpat phattpat is offline
New Member
Foam by Mail is local to me if anyone needs me to go there for anything!
Patrick
Old 01-12-2004, 12:21 PM
thanks for the links
Old 07-13-2004, 10:00 PM
Mr.Upholster Mr.Upholster is offline
New Member
Door Panels
What you need for your kick panels is waterproof panel board.....I have it in 2 x 4 sheets....also I have closed cell foam.... yes I do this for a living.......visit my site *** There is a lot of ways to do flames....you could screen them on and sew around the flames....the easy way....you could cut out your own flames out of red and orange glue them together with vinyl glue and sew them on your underware if you want to ......You could cut out foam in the shape of flames and sew fabric on top......you could go to walmart and get that cheap fabric they have with the flames and use that as a pattern ect.......
i CARRY IT ....How big a piece do you need""??? see my web site ***
Old 07-14-2004, 07:41 AM
Weimer's Avatar
Weimer Weimer is offline
Kenneth Howard hates you...
digging up old posts to promote your site, I see.... Thats good and all, but I don't think that will fly to well with the folks on the board. They like to call it "Advertising"
Later,
WEIMER
Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
