Foose still puts bondo on bare metal - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-02-2006, 01:49 PM
Slickriffs's Avatar
Did you ever notice that? Wonder if it's because of the
time deadlines or he believes it's a perfectly acceptable
practice?
Old 02-02-2006, 02:58 PM
I've been putting bondo on bare metal since the beginning of time and have never had it come off. This epoxy stuff hasn't been around that long. We were told to put bondo only on clean bare metal. I'm working on an old Chevy that was redone in the late sixties. The old lacquer paint is junk but all of the 40 year old bondo has held up great.
Bob
Old 02-02-2006, 03:28 PM
Bondo on bare metal
Old bondo on bare metal done sometimes in the 60's on the 37 chevy I am working on is really comming off hard. I have sanded, beat with a hammer, used a chisel, and pried with a screwdriver to remove it. I have heard that some chemicals will soften bondo so you can scrape it off easier. Anyone know what to use?
Old 02-02-2006, 03:59 PM
BarryK's Avatar
practice?
He does it both ways, usually the body will be epoxied and some of the other parts not, majority of time if allowed it gets epoxied.
On the chry not seen yet on TV the whole thing was epoxied.
Old 02-02-2006, 04:14 PM
Boy is this subject getting beat to death. I don't know what chemicals would soften the bondo. Not sure of what you heard of, wonder if paint stripper or the chemicals they use to dip bodys would have any effect, never tried any chemicals to soften it. Some people heat the old bondo with a torch. I still remove it the way i always have, grind it out, or dig away at it with a course sanding disk on an 8" orbital.
Old 02-02-2006, 05:15 PM
Custom builder and painter
Last journal entry: Another test fit of the axle
If I have to remove excess bondo on something.. I get out the grinder.. trying not to get into the metal though... when it get's closer I use a DA locked into the grind mode with 80 grit on it...
Old 02-02-2006, 08:24 PM
adtkart@aol.com
Usually Aircraft Stripper will soften up old body filler. It won't take it off, but will make it easier to scrape off.
Aaron
Old 02-02-2006, 10:17 PM
Slickriffs's Avatar
Yup..pick up some 24 or 36 grit round hard backed sanding disks..makes mince meat of bondo
Old 02-03-2006, 12:11 AM
www.1965comet.net
I use a wire wheel on my grinder....
Old 02-03-2006, 08:00 AM
Beenaway2long's Avatar
or Jeff, or Doc, or...
Last journal entry: Results of the Camaro
I use a propane torch. Just warm it up, and a hand wire brush pulls it off.
Like anything involving heat and metal.....don't be stupid and start rushing. Otherwise you will need Wray Schelins shrinking disk video.
Old 02-03-2006, 08:05 AM
i still use it over bare metal and have been doing it for 14 years now , when i first started if i used it over paint i would get shot buy the boss
as long as the metal is clean and is scratched up a little you will have no hope in hell of it lifting
"Basic of Basics" Welding - How do I repair body panels? Centerline Body - Exterior 33 03-31-2014 10:45 AM
Metal Finishing, let's talk about it. MARTINSR Body - Exterior 29 04-19-2011 09:47 PM
Bare metal prep greenmachine Body - Exterior 7 10-27-2004 07:57 AM
Bodyfiller - bare metal work etc vorgath Body - Exterior 2 09-17-2004 05:58 AM
Painting Dilema (Bare Metal 4 4months) 70chevy Body - Exterior 5 08-25-2004 10:02 AM
