Forced Air Propane Space Heater
The only down fall's with the forced LPG that I encountered was:
You have to have a place where things won't melt , burn or ignite. After a while the sound got to me so I gave it to a friend. The one with the stat is the way to go , hands down. I went with the radiant heater used with LPG , the space needed is minimal, and I mounted it as per instructions above the door with a squirrel cage fan to circulate the air around the shop. It is out of the way and doesn't make any noise. |
you can make a thermostat, use a line voltage thermostat, put it in a metal electrical box,be sure to ground all metal boxs or plastic box, (I like to make a wire or something thats mounted to the back of the box so it's easy to hang up anywhere) like a over sized electrical handy box. drop two 8 to 12' long cords with cord connectors out of the bottom of the box, and on one cord put a male end and on one cord put a female end on, then plug heater in to female end coming out of the thermostat and plug the male end into a 120v receptacle and hang the thermostat in the box up in a convenient place. then you can use this thermostat you made up on other heaters or at other garages ect. just a idea. it can be done for prob $20 or so.
Mustangsaly |
I just purchased a forced air reddyheater that is 35,000 BTU. I am also in Virginia and my garage is 20x22, detached, insulated walls and non-insulated attick. I used the heater the last 2 days when it was around 40 degrees outside. The heater brought the temperature up to around 57, then I cut it off because I was starting to get warm. This probably took around an hour with one window cracked and another cracked with a box fan blowing air out. You can definately smell it a bit, but venting helps. I would turn it on for a while, then cut it off. Worked pretty well. I could see having the next size up, though.
| Recent Garage - Tools posts with photos |
| 69 Camaro heater conversion | jearsley | General Rodding Tech | 7 | 08-17-2012 09:13 PM |
| larger compressor | gburgess2002 | Garage - Tools | 13 | 07-19-2009 09:36 AM |
| Air into the cooling system. | TVR383 | Engine | 7 | 04-11-2003 02:54 PM |
| Opinion of those tin foil air twisters | 5.0Towncar | Engine | 37 | 11-02-2002 04:34 AM |
| Which air cleaner? | alan.shields | Engine | 3 | 10-03-2002 12:16 AM |
