Forced Ind Torque way up but nec HP???? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-04-2011, 09:43 AM
bigalow's Avatar
I was punching some numbers using "CAM QUEST" and I noticed with even a small Turbo Torque Increases greatly at even 6psi and HP sometimes declines???
ex:
NA torque 398 peak
Hp 420 peak
add turbo 6psi
torque 478 peak
HP 410 peak
Same motor combo
Old 11-05-2011, 08:17 AM
bigalow's Avatar
I answered my questions. Forced inducton gives a motor more torque because essentially you are making it a bigger engine. More force when the cylinder combusts and forces the piston down=TORQUE
Old 11-05-2011, 10:47 AM
bentwings's Avatar
bentwings
Hopefully you will actually get to try it out in real life. Be sure to bring a doggie poop bag just in case.
I took a nice strong 355 NA and did a nice burn out for the shop guys. 18 hours later with the 6-71 and 2 750 dp I did it again..same motor. Not even the same car!!! haha Made believers out of the whole gang. 355 made like a 502 except idles smoother and gets better mpg.
Forced reading? BarryK Hotrodders Site Suggestions and Help 35 02-09-2009 08:50 PM
Forced induction q smokin63 Hotrodding Basics 6 02-22-2008 08:37 PM
forced induction and big heads firestone Engine 0 10-15-2006 09:35 PM
need help with forced induction thelastpalmer Engine 11 03-14-2005 09:45 PM
SBC 350 forced induction buildup sickgrin Engine 8 09-13-2004 08:07 PM
