Ford 14x8 wheel?
Did ford ever make a 14x8 magnum 500 type wheel? I have a set of four what look to be 14x8 ford magnum 500 type wheels. They have rings and center caps and on a tape look to be 8 inches wide. I'm selling them with new 205x60 rubber and am looking for an idea of their worth. Any ideas??
Are you measuring on the inside surface of the rim, or outside? You should be measuring on the inside.
Ontario Rodders |
Tires are still on the rims, but if measured to the outside of the beads they are over 8 inches wide. They are likely 7 inches wide measured with the tires off on the insise bead surfaces, but none the less the question is still valid.
The largest MAGNUM wheel FOMOCO offered was 14 x 7" or 15 x 7". They are available in aftermarket in 8".
