Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Ford 2.0 4 Litre Compression?
Old 07-12-2005, 09:36 AM
1931 steve's Avatar
1931 steve 1931 steve is offline
Last wiki edit: How to rebuild an engine Last photo:
Wiki Edits: 4
Run engine to operating temps, disconnect the distributor so not to have spark, open the throttle to full open and run compression test. Results should be 179 psi with a minimum of 142psi. Hope this helps.
Steve
