-   -   Ford 2.0 4 Litre Compression? (http://www.hotrodders.com/forum/ford-2-0-4-litre-compression-65707.html)
cspink 07-12-2005 07:59 AM
I have a 93 Ford Probe with a 2.0 lt that my daughter overheated. I have replaced the head gasket because I was told it was probably blown since there was verry little compression. I still get the same reading on my compression tester. Can you tell me what the compression reading should be? thanks
1931 steve 07-12-2005 08:36 AM
Run engine to operating temps, disconnect the distributor so not to have spark, open the throttle to full open and run compression test. Results should be 179 psi with a minimum of 142psi. Hope this helps.
Steve :welcome:
pmeisel 07-12-2005 09:18 AM
If it overheated bad enough there is a fair chance you have a cracked head -- sometimes the crack is not so obvious that you would see it without careful inspection.
Please don't ask me how I know this......
