Ford 2.3L cooling question - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-04-2010, 08:00 AM
Banned
On the Ford 2300 Lima engine, there is a coolant passage that flows through the factory manifold under the carb and into the cylinder head. Can I plug this passage and cap the line at the water pump or is it needed to have proper cooling flow? I fabbed up an intake and left this coolant port out, but I can add a brass fitting fairly easily if it will prevent cooling problems.
If I can leave it off do I just cap the port coming off the water pump or do I need to reroute it somewhere?
Old 05-04-2010, 09:42 AM
Last journal entry: 50 Ply wagon
That port needs to be there. It supplys the head with coolant. If you block it off, you could make the head too hot and warp it.
Old 05-04-2010, 10:01 AM
Banned
I figured as much. Would it be benneficial to move the coolant port to the rear of the head?
Fat fendered Ford question: loyter Hotrodders' Lounge 2 01-10-2008 05:38 PM
Ford Steel Wheel Tech wheelkid General Rodding Tech 9 01-07-2007 06:31 PM
ford truck question william r plise Body - Exterior 3 05-11-2006 05:38 PM
question for all you ford suspension guys Blag Suspension - Brakes - Steering 7 03-29-2005 11:59 PM
Ford 2.3L mods SAATR Hotrodding Basics 3 05-01-2004 03:56 PM
