ford 200 inline 6 question - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-20-2010, 08:07 PM
cutthroatkid's Avatar
two cups of tea
Last wiki edit: Need more horsepower for my 305 Last photo:
Wiki Edits: 2
Hey guys I bought an 80 mustang today&it has a 200 inline 6 I have a few questions first,can the intake be removed while the head stays?I've been told diffrent things,also is this motor the big bell?Id love any info on this motor&car thanx guys!
Old 05-20-2010, 09:23 PM
i have the same motor and trans
it`s a c-3 light duty small bellhousing.
the engine however has a small and large bolt pattern to get creative with.
im rebuilding my inline six since it spun a bearing due to lack of oil from caked on sludge deposits turning loose from *seafoam* and clogged my pickup tube. The rod was spun even before i got the car i bought it for 350 bucks with 109,000 original miles on it. i took the engine apart and found out that the cliner with the spun bearing was missing HALF OF A COMPRESSION RING!!! i was furious and confussed all at the same time. couldnt understand what kind of a NUT would do such a thing. anyways. the inline six is an awesome engine.very easy to work on and such. cam kits are available from summit. so are the headers. www.cliffordperformance.net, and www.classicinlines.com are good sites.
Old 05-20-2010, 10:28 PM
Wiki Edits: 31
'80 is a big bell engine, it is 3/4 of a SBF bolt pattern, and there is enough there ( 1 bolt won't fit ). to put just about any V8 transmission behind it.. you may note that the cylinder head and block casting is E0-BB. which stands for 1980 big bell.. no factory North american 200 I6 cylinder head came with a removable intake, and even the rare ( only 2 or 3 made ) experimental "X" casting head which is just a normal E0-BB head with a 2bbl carb plate cast in, is an integral design also... the intake can be milled off, and you could create a removable intake if you wanted, it has been done, but the E0-BB is known as the best factory north american head as it has the biggest valves and the best port flow... but if you want to make a lot of HP, ither turbo or N/A. those '80 engines can be turboed with a junkyard turbo fairly easy. but the real HP comes with the classic inlines alloy cylinder head, and a turbo. can push 10 PSI thru a stock '80 engine because the factory comp is 8:1 and the alloy head retains the factory cylinder head chamber size of 57cc.. if you get the compression to 8.5:1 it should gain more power with less boost... if you want N/A. just get the compression up with some Tempo/taurus 2.3 HSC pistions, that will also bring the pistions to zero deck. and you can mill .065 off of the head, which will yield around a 9:1 compression ratio
Old 05-20-2010, 11:07 PM
will the stock cast pistons hold up to the everyday usage of a turbo on these engines is my question?
Old 05-21-2010, 06:40 AM
Wiki Edits: 31
yep, shouldn't go over 10 PSI tho.. lots of stock blocks have been turbocharged successfully, and can be daily drivers.. they just need to be in tune. going lean will burn up the pistons
Old 05-21-2010, 08:00 AM
two cups of tea
Wiki Edits: 2
I know nothing about turbo charging&I mean nothing.
Old 05-21-2010, 01:03 PM
Wiki Edits: 31
nither did I when I built my turbo 6. but with the help of www.fordsix.com, I figured it out.. you don't need a perfect sized turbo to make power, or even an intercooler.. just make sure the turbo is for an engine of simmilar size. so the turbo from a 3.8 GN is just about perfect, and there are also lesser versions of the same turbo that were used on Regal Sports of the 70's ( carb'd drawthru setup )
Old 06-06-2010, 07:56 PM
Do u have any pics of your turbo setup?
Id like to take a look . PLZZZzzzzzz
Ford inline six to 2300 inline 4 swap. 74chevyflat Engine 3 05-20-2010 10:12 PM
Gear ratio question with 391FT Ford 57fordft Transmission - Rearend 20 03-28-2009 02:19 AM
66 ford c4 question Stangman196700 Transmission - Rearend 3 11-12-2008 10:27 AM
can i put an 250 inline carb on my1978 ford farmount kenarmy2001 Engine 4 07-19-2004 12:51 PM
I have a question about ford f150 Thuggishruggish3000 General Rodding Tech 2 12-12-2003 06:45 AM
