ford
hello, say i have a 54 ford customline. and it is custom. anyway anyone know how to run the wire to the gauge for my charging system. it is a loop style on the dash. i need to know how to route this. thanks.
I am not positive about the Ford way, but you can run a 12 wire from the output post of your generator up through the loop and then to the negative terminal on the battery (assuming you still have the positive ground). Then run the same size wire to the B post on your light switch. It should have a fuse on it. If it shows a discharge, reverse the wire down through the loop. I have the wiring diagram for the older Fords, but they had the cut out on top of the generator and not a voltage regulator
Trees |
| 1948 Ford stock engine/tranny with Ford 9" rear end | beek15853 | Transmission - Rearend | 5 | 04-04-2012 07:56 PM |
| 1934 Ford transmission with1948 Ford truck engine clutch questions | ppetrano | Transmission - Rearend | 1 | 05-20-2011 11:02 AM |
| 1948 ford f-1, 1981 ford f-150, mustang ll pile up | derrick_500 | Suspension - Brakes - Steering | 6 | 09-09-2008 01:17 AM |
| 1932 Ford rims Kelsey Hayes or Ford motor Co. | alf51chevy | Suspension - Brakes - Steering | 2 | 09-12-2005 08:14 PM |
| Ford Racing Visteon Ring & Pinion, 9" Ford ??? | acr | Transmission - Rearend | 2 | 07-23-2004 09:17 AM |
