The only thing I remember about my 302 was the rockers were a "torque and go". No adjustment, so to speak. The rocker pivot bottomed against the stud and then it just got torqued down and it was good to go.
289 Valve adjust
You have adjustable rockers so heres what you want to do,turn the engine over so the valves you adjust are in the fully closed position,do this one cylinder at a time,turn the adjustment nut down and rotate the push rod between thumb and forefinger while adjusting when you get to the point the pushrod no longer rotates add a 1/2 turn.A lot of people and books will tell you 3/4 turn but I have never lost a cam on break in doing it this way as that allows room for lifter pump up.Don't forget use Shell Rotella oil for that cam break in too,there are some excellent posts on here about that too!
thanks Jeffb, but i have a hard time telling when the valves are open or closed..ive got a mild cam so its hard to read them.. is there a formula for setting certain valves at tdc(compression) then turn the crank 180 and then adjust the remaining ones? thanks. or maybe a guage or indicator to check valves, to see if they are open or closed.?
Valve adjust
| 700R4 – Why are the TCI manual valve body instructions so lousy? | Bayley | Transmission - Rearend | 24 | 02-16-2009 12:49 PM |
| Need some info on Ford 289 and 302 water jackets | onebadmerc | Engine | 5 | 01-09-2006 08:40 PM |
| SBC 350 Valve lash !¿?¿ | boneyard Buick | Engine | 5 | 11-09-2005 08:21 AM |
| 1965 Ford Fairlane 289... go a little faster? | killerformula | Engine | 29 | 04-07-2004 08:08 AM |
| Whatever happend to these guys? | hot_rod_kid | Hotrodders' Lounge | 20 | 12-17-2002 09:20 AM |
