Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Ford 300 Inline 6 valve train problem
Old 09-12-2012, 07:58 PM
Augusto's Avatar
Augusto Augusto is offline
From the middle of the world
Last wiki edit: How to rebuild an engine Last photo:
Originally Posted by oldbogie View Post
I'm not to sure that lapping if that's all you did will be adaquate, especially if this is a heavy duty or an emissions head with hardended seats.
So that leads me to the question as to whether you used a seat cutter/ grinder before lapping? Lapping alone as a seat restoration process makes the seats too wide and the valve ends up not settling well on the seat. Also, did you restore/replace the guides. When these get loose the valve rather orbits the seat having a hard time setting itself down.
Bogie
I just lapped them to clean up the grime, the engine sat down for several years, the seats and valves are ok, not worn, so are the guides, they didn't need a restoration, the engine has low millage, they are not too wide now, I lapped them not to correct any problem, just a clean up job.
