Ford 300 Inline 6 valve train problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-12-2012, 05:43 PM
Augusto's Avatar
From the middle of the world
Last wiki edit: How to rebuild an engine Last photo:
I'm having low compression and vaccum reading issues due to the valve train not seating well,
I've made a compression test and it indicates valves not sealing well, I just lapped them so the seats are not the problem.
I belive they are kept open by the lifters.
Is it possible to convert them to adjustable, like the chevy engines?
Can I use chevy rocker arms in them? I6 or V8 pieces?
What is the rocker arm ratio of the I6 Ford engine?
thanks a lot.
Old 09-12-2012, 06:23 PM
BOBCRMAN@aol.com's Avatar
You did not state the year of your engine. Early 300 six engines use guided cast rockers that can be lashed. Similar to the 289-302 early rockers.
Old 09-12-2012, 08:36 PM
thanks a lot.
I'm not to sure that lapping if that's all you did will be adaquate, especially if this is a heavy duty or an emissions head with hardended seats.
So that leads me to the question as to whether you used a seat cutter/ grinder before lapping? Lapping alone as a seat restoration process makes the seats too wide and the valve ends up not settling well on the seat. Also, did you restore/replace the guides. When these get loose the valve rather orbits the seat having a hard time setting itself down.
Bogie
Old 09-12-2012, 08:54 PM
Augusto's Avatar
it's a 1987 engine, came out of a E350 Econoline, it's installed now in my son's Granada.
I don't know about the early 289-302 rockers, this is my first time I deal with Ford engines.
the rockers are cast not stamped like the chevy units.
you mean there's a way to adjust them valves? shims or something?
the truth is I would love having a chevy-like system, adjustable by turning them loose 'til they make noise then tigthen down 1/2 turn, you know what I mean right?
Old 09-12-2012, 08:58 PM
Augusto's Avatar
Bogie
I just lapped them to clean up the grime, the engine sat down for several years, the seats and valves are ok, not worn, so are the guides, they didn't need a restoration, the engine has low millage, they are not too wide now, I lapped them not to correct any problem, just a clean up job.
Old 09-12-2012, 09:43 PM
Early ( late sixty-early seventy) 300 use a crimped nut, similar to chevy. That can be used with the guided cast rockers. These adjust just like a chevy.
Old 09-13-2012, 07:49 AM
Augusto's Avatar
the nut just bottoms out and can't be adjusted any further, do I need longer push rods or do I have to machine down the head bosses or the rockers?
Need info on a 300 inline 6 Ford bowtieorbust Hotrodding Basics 37 06-09-2011 01:33 AM
Ford Inline 6 300 ( most miles ? ) crystalbluevib Engine 4 03-02-2010 02:37 PM
300 inline six ford steve stearsman Engine 5 12-23-2008 03:47 PM
1983 ford inline 300 robmccolery Engine 4 02-04-2007 06:36 AM
removing valve springs on inline ford 300 vistastudio Engine 1 10-09-2002 08:24 PM
