The car is running, the engine performs very well, better than I expected, it has as much torque as the original 351W, but it goes flat at top end, it's a low revs engine definitely.
I ended up using a chevrolet 2GC carb, I made a carb adaptor with 1/4 inch steel, that's like a box, about 1 inch tall, and as large as the carb's base, probably like 4x3 inches, one hole for the manifold on bottom side and two for the carb on the opposite top side, I don't like much the idea of feeding a small manifold hole with two bigger bores, but for now it's running great. I'm having this problem though, when I come to a stop in a traffic light, most of the times the engine stumbles and runs very rough, nearly stops and shakes badly, I have checked everything possible and impossible but can't find the problem, could it be the carb adaptor creating some turbulence or holding some fuel or something weird inside that causes this problem? the engine stabilizes and runs smooth after a few seconds, idles fine. I have not being able to determine if it's rich or lean when it happens, have tried leaning it opening a vaccum port but runs the same, also squirted some gas inside to make it rich but also runs the same, ignition is @ 10 deg, all ign parts are new. I have this turbulence toughts in my head from the adaptor, could this be possible? |
Have you checked the float?
Here is some info on 2GC: Rochester 2G, 2GC, 2GV Carbruetor Manual - The Old Car Manual Project |
thanks that site is quiet interesting, found some very good info on old stuff, I'm gonna tear the carb appart to see what's inside.
finally most of the bugs are killed
the car runs great after several issues with the engine main problem ended up being the valve train, not sure why it happened but had to shim the rocker arm pedestals to fix this stumbling and poor idle, the valves were not sealing well, after the shims, a brand new caburetor and electronic ignition the car runs as good as it did with the V8, it even has more low end torque than the V8 engine, since it's not a race car I'm very pleased with it's performance, my son drives it daily to and from college. the duraspark module quit once but it ended up being a wrong coil, at first I used a TFI coil but it overheated the module, I installed a universal coil with resistor and now the module runs almost cold. I ended up using two cooling fans one aft and the other behind the radiator, never had any cooling issues the C4 is giving me some trouble, sometimes it starts in second and others it won't shift to 3rd, but that's another story. I'm gonna lower the ride height now, it will look cool sitting a couple of inches lower. I'm leaving a picture of the engine bay with the huge I6 engine, and for anyone who dares to try this swap I definitely reccomend you do it, this 300 (actually 306 with the .40 overbore) has nothing to do with the anemic 230 and 250 engines that ford put in their cars. I bet a turbocharger and EFI will make it a real mustang eater. thanks to all for your comments and toughts, |
| The Following User Says Thank You to Highball For This Useful Post: | ||
larrys auto repair (11-10-2012) | ||
not sure if racing this engine would be wise due to the cost of the parts needed, but for a high performance street bound car I found it a real nice choice, maybe a supercharger, say a weiand 142, would be perfect for this engine, the turbo needs higher revs to shine but the roots blower will make a freight train puller out of this big block six.
| Ford inline six to 2300 inline 4 swap. | 74chevyflat | Engine | 3 | 05-20-2010 10:12 PM |
| 9" Ford Granada Rear End Question | cunningham | Transmission - Rearend | 2 | 03-28-2010 07:50 PM |
| Ford Granada rear end tag identification | CrashFarmer2 | Transmission - Rearend | 22 | 12-31-2006 05:23 PM |
| rag joint replacement on '78 ford granada | Scott Newcomb | Suspension - Brakes - Steering | 1 | 10-13-2004 05:08 PM |
| Ford Granada 77, HO? | Jeannie242 | Hotrodders' Lounge | 3 | 11-18-2002 06:37 PM |
