ford 302 (1977) - Hot Rod Forum : Hotrodders Bulletin Board
View Poll Results: what is best cam fo302 mileage to power ratio
300/500 0 0%
260/480 1 100.00%
Voters: 1. You may not vote on this poll
Old 02-28-2008, 12:19 PM
ford 302 (1977)
I have a 77 ford f-100 (302) i'm planning on rebuild..top & bottom , will redo stock heads.suggestions on work to be done to heads?? .030 overbore, any ideas on cam , carb , it is stock 2 brl 2150 now .. will be daily driver .. want most hp I can get and still get at LEAST 15 mpg will have duals , poss. headers, stock crank, auto c-6 ford 9" rear open to all suggestions. prefer no stall conv. but am open to sugg.. at least 15 mpg is a must!! not askin for much huh? lol
Old 02-28-2008, 12:29 PM
RippinRon's Avatar
Try and find some e7 heads from 87 and later 5.0's. They are much better than the e6 heads.
Old 02-29-2008, 12:07 AM
JeffB's Avatar
302 Build
Going to the E7 heads would be a good step,you should be able to use yours for core exchange check your local machine shops.302 Ford heads weak spots are limited exhaust breathing to offset that go with a cam that is a split duration, I would look at a Crower Baja Beast (www.crower.com) 15915 duration @.50 is 204 int 210 exh adv lift is 443 int 452 exh this will give you the torque a truck needs to get moving and good mileage.A Weiand action plus and 600 Holley would work well with it.Tri-Y headers will make good torque as well
Which heads should I use on 302 Ford? Coleman396 Engine 8 11-08-2008 02:29 PM
302 ford transfer tube between heads 39 chev Engine 4 10-30-2005 11:27 AM
Ford 5.0, 302, 351W Performance Info xntrik Engine 10 09-07-2005 12:01 AM
302 Ford Small Block Identification Drean Engine 6 08-08-2005 02:19 AM
Ford 302 into a 1940 Ford questions. cyberbear Engine 2 07-20-2004 09:29 PM
