Ford 302, 5.0 Engine timing - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-05-2006, 02:40 PM
I have a 1989 Ford Mustang LX 5.0, I recently rebuilt the engine. When I set it to top dead center and made sure the rotor button lined up with the dis. cap, it fired right up but only ran for about 15 seconds. After this every time I start it I have to place it a TDC and it will only run for 10-15 seconds. It also sounded like it was detonating in one or two of the cylinders if anyone can help me with this I would be very grateful!! What am I doing wrong?
Old 03-05-2006, 04:37 PM
aka Duke of URL
With the TFI ignition, base timing has to be set with the SPOUT signal disabled.
Old 03-05-2006, 07:12 PM
To KULTULZ
I am not familiar with the SPOUT signal. If you could elaborate on the subject I would greatly appreciate it. Thanx for replying!
Old 03-05-2006, 11:47 PM
aka Duke of URL
-AUTOZONE-SETTING BASIC TIMING-
Old 03-06-2006, 12:48 AM
Brian_B's Avatar
Lost in the 50s!
Last journal entry: time to start body work
Is it the 5.0 H.O. engine? I believe they have a different firing order than a normal 5.0 as well. Could that be part of the problem?
Old 03-06-2006, 09:24 AM
TechnTool's Avatar
OldSchool MotorHead
Be very very careful how you rout your ignition wires. These engines are known to crossfire from the factory and they can destroy themselves in the process. there is an old TSB on this subject. I don't hve a database right here, but if someone else could look up the TSB for 5.0 L for Mustang and Bronco ignitions and post it.
Distributor Tuning and Theory - Part 1 Rick WI Engine 35 04-26-2011 01:38 AM
Ford GT-40 Crate Engine Questions 31rdster Engine 8 11-27-2005 03:32 PM
Ford 302 engine motor mount location/measurements ctrammel Engine 0 07-26-2005 06:43 PM
What can I do to hop up this 197 hp 460 Ford engine onebadmerc Engine 7 05-25-2005 12:05 AM
1979 ford 302 timing DaveT Engine 2 09-30-2003 08:52 PM
