Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Ford 302 build
Thread: Ford 302 build
Old 04-04-2007, 07:42 AM
red65mustang red65mustang is offline
I was curious so I plugged in some #'s
typical mild build 302=269 FWHP/302 TQ at peak
same motor at 331 cubes= 270 FWHP/328 TQ at peak
not "exact" but the approx 30ft/lbs more is evenly distributed across the whole rpm range....curves are parallel(?)
alot cheaper and way simpler to swap rear gears to gain ft/lbs at the rear wheels
302ftlbsx3.00 gears=906 ftlbs at the rear wheels
302ftlbsx3.50 gears=1057
328ftlbsx3.00 gears=984 ftlbs at the rear wheels
spend the 331 $$$$ on a AOD and have the best of both
it's TQ that makes a fun street car....
