Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Ford 302 build
Thread: Ford 302 build
Old 04-04-2007, 11:25 AM
aka Duke of URL
The 1968 302 4V is already 10:0 to 1 from the factory. You only need to open the exhaust ports on the heads. If one was to use either 289 HI-PO or later 351W exhaust manifolds, it should not be that noticeable. That and the new dualing exhaust will make a lot of difference.
Ditto on the 1.12 AUTOLITE...
Do you have the 4100 or the 4300 Series? It could be either on the 68.
Now...did you ever see the SHELBY accessories catalog for the COUGAR?
I just have to aggravate a little...
