Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Ford 302 Engine Question
Old 01-27-2004, 10:37 AM
brainsboy's Avatar
brainsboy brainsboy is offline
brains
If you do a 351w find a 69-74 block as they have a thicker webbing and can handle more HP, as a note the 74 block has a 9.5" deck height and the 69-73 has the 9.480". Both blocks will work but there will be a little difference in compression and the older blocks use a 8.150 pushrod and 73+ uses 8.205 is I remember it correctly.
Good Luck
