ford 302 fuel injection and aod trans - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-06-2005, 07:43 PM
39 chev's Avatar
Last journal entry: new pictures of T-bucket
I am helping a friend on his 48 ford truck project,and we need a little information.We have a 1986 fuel injected 302 and aod trans{not sure of the year of the trans} can we use an inline fuel pump with this injected motor{truck has an aftermarket fuel cell,and no in tank pump}also what about the trans do we need a computer to control the shifting? I did a search and did not find this info anywhere else. I understand that this engine has a roller cam and needs a distributor with a steel gear,Is this correct?
Old 08-06-2005, 07:53 PM
edge's Avatar
Time is short, are you ready?
Don't know about the Ford AOD or the distributor gear, but yes, you can use an externally mounted high pressure pump. One like the MSD #2225 will work. You can also get one similar that will work at Carquest, P/N E8248 for about the same price. I bought one and it works fine with my 383 SBC MPFI system and has a lifetime warranty.
And don't forget, you will need a return line to the tank.
Good luck with your swap, Ed www.edgesz28.com
Did You Know?
Old 08-06-2005, 08:12 PM
what does a dis gear have to do with it...if its an older style regular aod it shifts by a linkeage ..connected to the throttle..if its a newer one it is computer controlled.
Old 08-06-2005, 08:15 PM
edge's Avatar
He asked three separate questions.
Ed
Old 08-06-2005, 08:59 PM
lluciano77's Avatar
The Mallory Unilite distributor will work with the roller cam. I don't know how it will work with the EFI computer.
I went carbureted with my '90 5.0. It is in a '61 Ranchero. Once you get that thing going, you won't be dissapointed.
Old 08-07-2005, 04:48 AM
The AOD is mechanically controlled, no electronics
other than backup light & neutral safety switch
neither of which are required to operate the trans.
That 302 (is it an HO out of a Mustang or is it throttle
body injection?) if it's an HO takes 39 lbs fuel pressure -
that's what the regulator on the pass side rear of the
fuel rails keeps it at.
If you don't have a distrib with the motor, just go
get a 302/5.0 distrib out of any 86 - 93 Mustang 5.0.
It will have the correct steel gear on it.
Just FYI, here's some info on AOD's
http://www.lincolnsonline.com/article111.html
stock AOD converters have a notoriously low stall speed
You can use a V6 AOD converter for a cheap upgrade
with no durability problems in a relatively stock V8 5.0
There's no lockup clutch in them - lockup is accomplished
via an input shaft that is mechanically connected inside
the converter on the front end and drives the direct
clutch pack on the back end.
Old 08-08-2005, 05:08 AM
39 chev's Avatar
302 ford distributor
I am not Ford guy,but from what I have heard that using the wrong distributor gear will chew the gear off the roller cam. the flat tappet and roller cam use different gears,but I dont know which is which.
Old 08-08-2005, 05:24 AM
39 chev's Avatar
302 ford info
Thanks for the help guys,I will be at the garage later this week and will try to find out exactly what we are working with.the trans came with the truck,and the engine came from another rodder who rebuilt it and never installed it. The truck had a 302 with it, that was "rebuilt",but when we pulled the intake,the valleywas full of sludge. if it was rebuilt,it must have been a long time ago. seems that just about everything that is for sale is "rebuilt".
Old 08-08-2005, 01:02 PM
Yes, the correct Ford distrib gear (at least when new) has a yellow stripe
on it. It's a steel gear.
Old 08-17-2005, 11:18 PM
xntrik's Avatar
Save a horse, Ride a Cowboy.
302 fuelie, it is really a 5.0....
Auto Zone sells a US made brand fuel pump that the car manufacturers use... under the part number E-2000. It is a frame mounted pump that will supply all the fuel for a moderately modified 5.0 and not suck a lot of electricity and not noisy. Another good application is the Ford pickups and vans with single fuel tank systems that have a frame mounted pump. These pumps suck fuel up well, and support the fuelie system. Dual tank systems have electric pumps in each tank to enable the switching of supply tanks, so their frame pumps do not work. Use the standard Ford replacement inline filter for best results. Fuel pump About $ 100 with lifetime warranty. I also recommend a normal steel-cased inline fuel filter, like a GF2, on the suck side of the pump to filter trash before it ruins the pump.
"Steel" roller cams require gears made of differnt material to prevent failure than those used on cast iron cams.
Old 08-18-2005, 01:22 AM
aka Duke of URL
Does the transmission have an Assembly Code Tag on it? You should identify the year if possible. Also be aware of the TV cable setup to control shifting.
The dist. gears are available separately through FORD RACING PARTS. If it is an 86 (and has not been modified), it has the roller cam and the proper TFI distributor.
On the fuel pump. A rail mount can be used but be aware that some early applications used two different pumps. One would be in the tank (low pressure transfer) and the pressure pump would be on the rail. Tricked a whole bunce of techs over the years...
You want the pump to sit below the actual fuel level to allow fuel to be drawn by gravity to the pump inlet. This prevents the pump from heating itself (that is reason pumps are in tanks) and burning itself out. A large pre-pump fuel cannister and a finer filter before the fuel hits the rail. You need a return line also as mentioned. Don't forget about venting the tank.
Old 08-18-2005, 10:55 AM
Arrowhead's Avatar
EFI Rules and Carbs Drool
Last wiki edit: The FREE T Bucket plans
Last journal entry: Sold Everything for a new project
Wiki Edits: 5
39 chev,
I used a similar setup in building my T bucket. It's a 302 from an 87 Ford Van. I used the AOD and the fuel injection. The other posters are correct on the AOD not being shifted by the computer. However, the there is a computer connection to the speed sensor on the transmission. I don't believe it was for the speed control either, that had it own control box that the speed sensor also connected to.
I connected the fuel pump to the bottom of the tank an the fuel gravity drains into the pump. I did not use the in tank pump.
I'm not sure which EEC you have, but mine controlls all spark timing and advance fuctions. It is the TFI style distributor.
The motor is basically stock, but it has over 2000 miles since I put it on the road this year and everthing seems to be working fine.
Old 08-18-2005, 04:36 PM
Siggy_Freud's Avatar
If I remember right, the E-2000 is a low pressure pump that wont supply enough for a multiport FI system running in the high 30PSI range.
However, you can pick up a inline fuel pump designed for an 85 4cyl FI Ford Ranger at autozone for like 89 bucks. Provides me with all the pressure and flow I have needed so far.
Bringing history and technology together.
Old 08-19-2005, 09:49 PM
xntrik's Avatar
The E-2000 is the pump that was used on the German built Ford Merkur 2.3 Turbo and puts out zero vacuum pressure on my 5.0 HO 5 spd. installed in a 63 Fairlane. I have had no pick up problems and no fuel delivery problems (10 years) and the return line goes into the fuel tank drain plug hole.
"zero vacuum pressure" = contrary to popular belief, fuel pressure is set by removing the vacuum line from the regulator simulating full throttle zero vacuum conditions/ maximum fuel pressure. Checking the regulator pressure with the vacuum line installed and while the engine is idling does not give spec readings.... This is why many people end up with excessively rich mixtures.
