Ford 302 HO Distributor ??? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-18-2012, 11:07 AM
awert's Avatar
58/58
My 1988 302 HO is being converted from EFI to Carb. can i use the existing Dist.? I was told that a dist from a 85 stang will work good, is the 85 a duraspark set up? I can't afford a fancy MDI or expensive unit, I just don't feel the existing EFI dist will do it. I'm aware of the roller cam and gear, don't even think of suggesting sticking to EFI... i think all that clutter ship is a PITA....
Old 02-18-2012, 12:28 PM
Canzus's Avatar
a red wool sock on his dinger
You can use any Duraspark distributor, just change the gear to what your cam will work with...
Old 02-18-2012, 01:39 PM
awert's Avatar
58/58
but is the 85 stang dist. a duraspark distributor?
Old 02-18-2012, 02:19 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Yes if it is the orginal piece it should be a ford motorcraft duraspark . JMO
Cole
what MSD distributor ford 302 COUGARPOWER Engine 3 07-08-2009 05:08 PM
Ford 292 vs. 312 distributor use BobWishart Electrical 2 01-27-2007 06:45 PM
Ford distributor ID oldred Engine 3 11-28-2006 05:31 PM
Ford 302 new distributor---HELP awd_maine Electrical 4 11-20-2006 12:58 AM
Ford Distributor question '67Pony Engine 0 08-13-2003 09:40 PM
