Ford 302 Indentification - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-29-2004, 11:45 AM
denwowo's Avatar
Talking Ford 302 Indentification
I have a 302 Ford a want to know which year its made. The 302 Ford have a head casting code 6K24 and roller cam
Old 10-29-2004, 11:50 AM
brainsboy's Avatar
brains
Your looking at the wrong numbers. The best place to look is right above the starter on the Block. It will start with a letter
C == 60's
D == 70's
E == 80's
so looking at a number C9, would be 69, and E6 would be 86.
Hope this helps.
Ben
Old 10-29-2004, 06:15 PM
aka Duke of URL
Arrow
6K24 is the casting date code. If the engine is a true 5.0L roller, it wiill be an '87 (6=1986/K=OCT/24=Day of Month). If it is an HO engine, it should have an E7TE head I.D. casting no. Standard 5.0L should have an E6SE head casting I.D. no.
Also look at the pan rail for the block casting I.D. no. as mentioned.
