Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Ford 302 - Intake bolt broke off in the head
Old 02-13-2013, 08:24 PM
prumora1 prumora1 is offline
on the 5.0 heads the front and rear bolt holes extend all the way through the head. so you can drill completely through the bolt with a 3/16 bit, next a small bit of heat from a propane or map gas, that will get it just hot enough then use a easy out and you can run it or out, just if you take it in don't let it fall in to the block.
