Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Ford 302 - Intake bolt broke off in the head
Old 02-13-2013, 08:30 PM
Torque454 Torque454 is offline
Originally Posted by Irelands child View Post
You can try heating it, but NOT to cherry red, just pretty warm. Once it's good and hot (but not THAT hot) you can melt some candle or canning wax into the threads. Then that 3/16 hole that you drilled through that 5/16 bolt before you heated and drooled the wax can be used with an extractor. Words of warning - use at least a 135 degree tipped cobalt drill bit as Ford tends to use Gr 8 bolts. The junk from your local hardwre store probably wont do it. Here's some drill descriptions from McMaster Carr - and it only takes a couple days to get an order to you - McMaster-Carr
Yep im thinking it needs to be hot, not red hot but hot, and use an EZ out on it. If that doesnt work I guess its off with the head and down to the machine shop :o
