You can try heating it, but NOT to cherry red, just pretty warm. Once it's good and hot (but not THAT hot) you can melt some candle or canning wax into the threads. Then that 3/16 hole that you drilled through that 5/16 bolt before you heated and drooled the wax can be used with an extractor. Words of warning - use at least a 135 degree tipped cobalt drill bit as Ford tends to use Gr 8 bolts. The junk from your local hardwre store probably wont do it. Here's some drill descriptions from McMaster Carr - and it only takes a couple days to get an order to you - McMaster-Carr
on the 5.0 heads the front and rear bolt holes extend all the way through the head. so you can drill completely through the bolt with a 3/16 bit, next a small bit of heat from a propane or map gas, that will get it just hot enough then use a easy out and you can run it or out, just if you take it in don't let it fall in to the block.
Borrowed a mapp gas torch today. Gonna try it and the easy out and see what happens. It soaked in PB blaster overnight and i sprayed it again this morning before work. Now im about to go out there and work on it some more and see if i cant get that bolt out...
I just did this yesterday on a Saab(can I say that here?)
The exhaust studs broke off, oh, about 1/8 into the head. I build up a tower of weld. Basically one bead on top of another till it protrudes above the surface then weld it to a 3/8 nut. Dude, it might take a couple of tries but it works slicker than ----! I got 3 done in 1/2 hour, no drilling. You got a mig? set the temp a little on the hot side aim for the center of the bolt and take your time. Just a suggestion .
| 302 ford intake manifold | greazyball | Engine | 5 | 12-02-2012 11:56 AM |
| need help with ford 302 head | #1spudman | Engine | 2 | 11-11-2011 12:27 PM |
| 400 sbc Head Bolt Broke | manchildau65 | Engine | 15 | 07-12-2009 07:25 PM |
| Found broken intake bolt in head | Skipr | Engine | 4 | 08-06-2006 07:36 AM |
| 5" waterpump bolt (Ford 289) head broke off and frozen in waterpump | ccarccrazy | Engine | 6 | 07-14-2006 02:31 PM |
