Ford 302 Interchange - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-19-2009, 08:51 AM
Hey guys,
A friend of mine burned up the engine in his 88 4x4 Bronco (EFI). He said it started running bad, pulled over, and popped the hood. It was glowing red on the manifolds.
I compression checked it yesterday and found a completely dead cylinder only halfway through. It still runs but I also hear a disturbing clatter coming from the motor as well; sounds like the valves or lifters. Anyhow, because he is down on his money, the decision is to pluck a motor from the local "u pick/u pull" junkyard.
As you can guess from my handle, I am chiefly a GM guy so I need some help with the interchange. Its an automatic btw. Obviously, an 88 Pickup or Bronco would be ideal, but what other years would be OK? What about a car motor like a 5.0 Mustang? I figure a car motor would be tuned differently, but we might have to take what we find.
Any help you can provide is much appreciated.
-J
Old 10-20-2009, 02:25 AM
JeffB's Avatar
5.0 aka 302
From 1985 to 1993 all 5.0's would be OK to swap as these are all roller cam motors,It would probably be best not to use a 5.0 H.O. since your Broncos' computer would not be compatible with it, also using the F.I. from the Bronco would keep things simple.
Old 10-22-2009, 09:27 AM
Thanks for the info. We will definitely be using the old computer, FI, and accesories. The salvage yard is only going to let us have the "long block" assembly unless, of course, we want to pay more.
-J
Old 10-22-2009, 11:04 AM
5.0
truck 302s or 5ltrs did not use roller camssoany 302 could easly be adapted from 1980 to last built,roller cam engines would work as long as truck manifold and injectors used. cliff
Old 11-04-2009, 08:03 PM
SBF swapp'in....
So long as you use the "use-able stuff" off the Bronco any 289/302/5.0 long block will work. All the way back to the 60's! Just swap the water pump and etc. off the blown engine.
6sally6
Old 11-04-2009, 08:13 PM
old76c10's Avatar
all jacked up on mountain dew
the HO engine will work with your computer as long as you use your intake also that same computer will run a 351 5.8 as long as you got the intake for that engine but you will have to build you a new y pipe
Old 11-04-2009, 11:00 PM
onebadmerc's Avatar
I need a bucket of arc sparks
6sally6
This is not true, you will have to use a 5.0, 289-302's are balanced differently. On top of that they have a different firing order, your computer is not compatible with the old 289-302 firing order. In 1985 Ford went to roller cams in the 5.0's which also meant the distributor gear is different than the old 302. I can list more issues but do you really want to hear how different the 5.0 is from the old 289-302. Your best bet is to look for a 5.0 out of a 85-96 truck. I think the 97 and later 5.0 engine went to the P head but I am not 100% sure on this.
Old 11-05-2009, 12:08 AM
old76c10's Avatar
the only diffrent firing order is on the HO engine his rig is not mass air controlled so as long as he has the right firing order the computer will run it..speed density fires the injectors bank to bank all the 5.0 302's didnt come with a roller cam they were set up for them but most trucks didnt have rollers until mass air was introduced in trucks
Old 11-05-2009, 08:37 AM
Onebadmerc IS correct...to a point......
For an absolute swap over with nothing changed...no thinking involved... no common-sense deductions made...he's right...it's not a STRICTLY bolt-in swap. But if his GM MECHANIC need a strictly..."pull his engine...slap another FoMoCo engine back into its place" kind of swap over...he has more problems than a burned up engine. The cam and distrib gear from the junkyard engine can be used. Just re-wire the cap. A different flex plate will need to be used(probably get THAT from the same junkyard too)
Not arguing....just stating a few things will need to be changed to use an older FoMoCo engine. This IS a hotrodding site after all! It sounds like a certified mechanic is asking the questions. Even they consult manufacturers engine manuals before they dive into a strange engine.
Sorry if I messed anyone up,
6sally6
Ford 302 cam help Les's73F100 Engine 8 10-19-2009 06:54 AM
302 ford transfer tube between heads 39 chev Engine 4 10-30-2005 11:27 AM
Ford 5.0, 302, 351W Performance Info xntrik Engine 10 09-07-2005 12:01 AM
302 Ford Small Block Identification Drean Engine 6 08-08-2005 02:19 AM
Heads for Ford 302 Coleman396 Engine 12 03-31-2004 09:51 PM
