Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - ford 302 motor mounts?
  #16 (permalink)
Old 12-29-2012, 08:50 AM
timothale timothale is offline
Wiki Edits: 27
biscuit mounts
Those rubber biscuit mounts work OK for an automatic trans, but some clutch chatter can result on a stick shift open drive line setup . They were designed for 1930's technology, My 2 cents worth, I would use the factory mounts with frame brackets you show but a tube for the front to back factory bolts.
